- May 11, 2005
- 226
- 0
- 0
lm running 2.5.5 fraps, regestered , its run perfect on the AMD 3200+ in games like bfv , half life and battlefield 2 , bf2 fraps at 10 to 30 fps on the 3200+, so l installed fraps into my AMD fx55 [ a better chip ! ] and it seems to frap [ record mode ] at 4 and 5 fps every time, lve tryed half size and a few other tricks, but it cant even do what the 3200+ can do under the same conditions , so , lm leaning towards a cpu technical possibly in the bios, to fix it, but im at a dead end as to do what next, lve even tryed stopping side band addressing to the cpu ! no work...
So have any of you out there had this problem ?
Does anyone have an AMD fx55 ? Can you install fraps and see what fps you record at ?
fx55 has sata hard disc scsi x2 on raid 0 [performance ], 2 gigs of pc3200 ram, x800xt,
the
3200+ ,sata x2 raid 0, 1.5 gig pc3200 ram, x800pro...
bfv 3200+ frapped at 40 to 50 fps
bfv fx55 frapped at 4 and 5 fps ...
ANY IDEAS ?
the
ANY IDEAS ?
