Originally posted by: Gautama2
Movies run at 27 fps.
But I wouldn't use 30 as an average. 30 would have to be the minimun the card ever put out. If your card only averaged 30 fps, then to me that isn't playable. During lots of fight scenes, etc, that's going to drop to a slideshow.Originally posted by: DSF
Most people use 30FPS as their cutoff point for playability.
Originally posted by: wolfy87
How many fps do I need to have when testing a game, so that it can be playable on my computer or with my video card?
Which number of frames per second is required to allow me to normally play the game?
Originally posted by: taltamir
lyssword made a funny... he has a point but most LCDs can only ouput 60 fps max... anymore and its just not being displayed. (your monitors refresh rate in Hz is how many FPS it can do).
Originally posted by: aeternitas
HZ is lagacy on LCD.
Its seems alot of you are working on logic from CRT monitors, and just assuming it works the same, even though its obvious when first looking at a LCD, that they are two very different technologies.
Basically, ignore the hz rating. It has no relevance to a LCD as there is no screen refresh, the refresh is per pixel, and still does not work off the HZ rating either. HZ is lagacy on LCD.
Freudian slip?
I love it when the *expert* opinions roll in on a thread
btw - I saw an eye test where fighter pilots recognized shapes of planes in a darkened room at some unbelievable rate - I can't find the link - but I found this on hand-eye coordination. . .
Best I did was 13 seconds!
Freudian slip?
Nice test man....I tried it out and...
My personal best 19.656
my LCD can do 1280x1024 75Hz
Your framerate can exceed your refresh rate, but it causes screen tearing. To avoid this you enable v-sync. Which locks the fps to your refresh rate.
