Originally posted by: intogamer
So the GPU could use the horsepower on other things?
Mainly to keep it from lagging
Originally posted by: SonnyDaze
I believe the frame limiter (like V-sync?) is there to prevent/reduce tearing. This occurs when the game starts sending more frames than the video card can produce in a pass. Or some nerdy sh*t like that.......
Unless you simply use V-sync, which will cap the framerate at your refresh rate, which will definitely be higher than 30Hz.🙂
V-Sync caps framerate at 60FPS to prevent tearing.
