Fractal R3 and Thermalright 120 Extreme
zod96
2,872
68
Does anyone know if the thermalright Ultra 120 Extreme fits in this case?
aigomorla
21,042
3,522
http://www.fractal-design.com/?view=product&prod=48
that is a rear 120mm fan, and u have enough clearance after the rear IO plate.
So i would say 99.9999% yes, you can fit that sink in there with a 38mm fan even if you wanted.
SmCaudata
969
1,532
Fractal design has all the important capacities on their site. 165mm tall cooler will fit.
