Fractal Design S Corsair Watercooling Mounting Issues
ScottFern
3,629
I am currently in the middle of a rebuild of my gaming rig and I've decided on a few new components:
Fractal Design S (Windowed)
MSI Z97 Gaming 5 MB
Sapphire R9 290 Reference Video Card
CPU Cooler - Corsair Hydro H110i GT
GPU Cooler - Corsair Hydro H60 + HG10 A1
I've decided to mount the H110i on the top of the case and that seems to provide enough length for the block to get to the cpu, but when I tried to mock up the H60 mounting it on the front of the case it does not appear to reach the GPU core location.
I am now re-considering using aftermarket watercooling on my graphics card now. I know the R9 290 runs very hot and loud while gaming, but I am running out of ideas on how to make this setup work.
Maybe I just need a different Corsair cooler that has more length? I am having trouble finding tech specs that list out the tubing lengths across all hydro models.
Aikouka
30,383
912
What about mounting it on the back as exhaust? Sure, it's not an intake, which means the air won't be as cool, but it won't be that big of a deal.
ScottFern
3,629
Can't with the top mounted H110i and its fan it only leave enough room for a 140mm fan and that is it. No room for the radiator.
Kenmitch
8,505
2,250
Can't you just mount the H110i up top shifted towards the front of the case? Looking at case specs leads me to believe it will work.
hack_tc
45
I run my H110i gtx in the front of my define s in the pull configuration. This should leave you plenty of room to mount the h60 as back exhaust. Id setup the fan on that one as pull as well so the radiator is easier to clean.
