Fractal Design R4 or XL R2 for this build? And Fan set up. Quiet and cool PC
-Mav-
Hi all
Which Fractal Design case of R4 or XL R2 should I use for a quiet pc that I will want to overclock (CPU and GPU) a bit but nothing hardcore?
Cost and space it not imporant in this situation so I can go for a bigger case. That should give better air flow and lower temperatures anyways right?
Build:
Motherboard: Asus Z97 Deluxe
CPU: i7 4790K
GPU: Asus GTX 780 Ti, 3GB
PSU: Corsair RM850
RAM: Corsair Dominator Platinum, 16GB (2x8GB), 2133MHZ, CL9
Drives: 2 x SSD
CPU Cooler: Corsair H110 (Fans replaced with 2x Noctua NF-A14 PWM)
Other fans: Replaced with Noctua NF-A14 PWM
If I choose the XL R2 then I will change all fans with Noctua NF-A14 PWM and adding extra. Basically 2 front intake, 1 bottom intake, 1 rear intake (need to buy extra dust filter) and 2 top exhaust (via Corsair H110 CPU cooler/radiator). I am thinking about connecting the 2 top exhaust fans to CPU Fan header with Y splitter. Unsure how to connect the remaining 4 intake fans, either all on CPU_OPT with 2 Y Splitters in serial (is this possible?), Rear and Bottom on CPU_OPT and remaining on CHA_Fan1/2 or all 4 on CHA_Fan1/2/3/4? Any ideas? Will run silent profile in Asus Bios or Asus software and only want it all to ramp up automatically if temperatures get (too) high.
Also, should I use the LNA adapters that come with the fans to reduse max speed to 1200 RPM in addition to auto control via BIOS/Software? I know some will advise that it is no point in case intake fans being PWM, but they should give better air flow and be better at auto adjusting than a 3 pin connected to the motherboard?
Not sure on how fan set up will be in a potential R4 case.
A lot of questions here, hopefully not too many.
Thanks.
Also, forgot to add that I will want to run SLI at a later stage. Will that build fit into r4? Assume xl r2 is big enough or can the height of Ram, length of GPU or anything else be a problem in any case?
