I'm going to get IvyBridge, and after seeing some threads about how it might overclock, I'm seriously considering getting a watercooling setup (my first ever, never done water before).
Ideally in my mind, I would mount the radiator externally, so that heat is dumped out of the case, rather than internally, because I see that as a big advantage of water.
I have already bought a Fractal R3, and it seems to have a couple of holes in the rear through which pipes could be run outside the case
There are also two 140mm fan mounting areas on the top of the case.
Would it work to mount the radiator above the the top fan holes, and mount fans inside the case to blow out over it (meaning the fans are inside the case, somewhat reducing noise from them).
I'm only planning to do a single block, cooling the CPU, and have the GPU air cooled because I'm not intending to go crazy with whatever I get.
Would it even make that much difference to the general case temps to mount the radiator externally?
The only thing I have at the moment is the case, no watercooling kit.
