- Mar 22, 2006
- 14,264
- 3
- 81
I received my Scythe Slipstream 1200RPM fans yesterday in the mail, and proceeded to spend my night putting together my rig and doing all the cable management. My current cooling scheme is: two front intakes, one rear exhaust, PSU exhaust (XFX Pro 750W XXX Edition), and either a side or front top intake, along with a Hyper 212+ and a Palit GTX460 Sonic 1gb GPU. All four of the Slip stream fans are hooked up to two of the fan controllers the Fractal comes with - supposedly 6v -> 12v adjustment, on a PCI bracket.
I decided to run a side intake for now, because the Palit's stock fan (80mm) gets screamingly loud when the GPU hits full load, and I want it to get all the cool air it can before I replace the cooler with a Scythe Setsugen 2, possibly with a 120x25mm fan.
However, at full 12V, besides the "whoosh" of air from the front and back fans and the whine of the CPU and GPU fans, I noticed a very distinct tonality I hadn't heard before coming from the case. Undervolting it reduces the tonality, but it's still present, and a little annoying. I took off the side panel and confirmed that the noise was coming from the side fan alone, and if I put my hand over the vents, the turbulence increased but the whine went away. Even when the fan is undervolted to 6v and attached to TWO 12v->9V adapters from Jab-Tech, the whine is present. Has anyone else experienced this with an R3 side intake fan? Would swapping to a 140mm fan make a difference? Maybe a different bearing type - BB or FDB?
