They used a longer power supply.
The X560 is only 160mm long.
Powercolor 7950 is 275mm long
Per Fractal's guidelines:
Graphics cards, up to 310mm in length, when 2 HDD brackets are removed (Graphics cards longer than 170 mm will conflict with PSUs longer than 160mm) Link
