Question Fractal Design Meshify C Case with a Corsair H115i Platinum RGB
Dave3000
1,543
114
I plan on getting a Fractal Design Mesify C Case when I upgrade to a new CPU and motherboard. Is there going to be a problem installing a Corsair H115i Platinum RGB in this case?
sandorski
70,819
6,365
Should fit in Front, but Top might be iffy depending on whether it is using 120mm or 140mm fans. 120 should fit, but 140 will be hitting Motherboard components.
Stuka87
6,240
2,559
The H115i is a 280mm rad, which means it uses 140mm fans. The motherboard is really high up in that case, so not all coolers will fit in the top mount.
Reactions: Makaveli
