Hi all,
new to this forum but not to anandtech but figured I'd drop a message and see if people had any thoughts, comments or ideas.
Picked up a Fractal Define R4
I've gotten the case up and running and love it but so far have had/have 2 "minor" issues..I don't know if it's design flaws, me or what the deal is per say:
- First off: The wires to the "control panel" on top tends to stick down abit, essentially blocking the top 5,25 inch slot. I was installing a dvd burner there for the occational use it does have and found myself having to use alot of force to get it in...and gave up out of fear of ripping the cables.
- Second off: The jack for headset on top seems to have issues accomendating headset jacks. I'm sporting a standard 3,5 mm jack for sound n speaker, but the casing around the jack seems to be too thick for the plug...doesn't fit in, but can just barely make it in enough to establish contact.
Does anyone have the same experience or any thoughts on this?
( Besides me possibly complaining or pondering over trivial and minor things
In addition to that I'm considering additional "sound/temp" reduction options as well as general sys. optimization ( know that's not for the case forum )
I'm running with an older ASUS RoC Maximius III GENE mATX P55 mobo with a i5-750 w std cooler and 2x4GB Corsair XMS3 mem on and then a new Gigabyte NV 660 OC GPU along with a OCZ Vertex 3 256gb
I'm considering throwing a Hydro H80i on the CPU allthough it might be overkill, but it seems to strike a nice balance between temp and noise.
Is there any other "relative" low cost suggestions that'd be worth taking a stab at?
( I know changing mobo would be a good idea maybe..given it's a 6gb/s ssd on a 3gb/s interface ).
Looking forward for feedback ( and flaming as long as there's still some constructive part in it )
