fps test thing!
sash1
There is a program that displays two moving blocks side by side and you can dictate what fps to run them at, where can I get that? Used to have it, but after my reformat I lost it.
Thanks,
~Aunix
Update-- found it here. I think you all should take a look
sash1
haha, that actually wasn't what I was looking for, but thanks anyways. I actually found the thing. Took me a damn long time, but I searched for myself (heh :D) under archived messages and finally came across it. If you all are wondering what I was looking for, its here: link
Anyways, this program is amazing, and I think you all should use it. 30fps looks so much worse on this than I thought I would. And 100fps is so much better than 60fps its freaky. :D
Thanks anyways, BoomAM :)
~Aunix
AgaBoogaBoo
26,108
~Aunix
Neat program, I'm glad I found it
Megatomic
20,127
You ought to compare 150fps to 20fps... And to think some people think it's fine to play with fps as low as 20. :(
BoomAM
4,546
~Aunix
Thats alright. You`ve helped me enough times, so i`ll try to help you (and others) where i can.
