FPS ONLY 75!!! in CS Source with ATI X1900 crossfire Setup HELP!
Keysplayr
21,209
50
Originally posted by: Ulfhednar
Originally posted by: keysplayr2003
You're not going to let it go eh? Ok, If it's that important to you to be correct, you win.
Not important enough for me to continue.
Thank God. I am of the opinion that you would've ignored that post entirely in the first place if it wasn't authored by me.
Ouch.... A little self-importance issue there. GLWT.
imported_ubigosong
15
Ok guys sorry if I go over stuff that has already been said, but I just dont want to read the posts.....
OK Set everything in CSS to highest, then type net_graph 3 in consol to display the frame rate. You might also have to turn off v-sync.
Then open up the consol and type these comands.....
fps_max 400
rate 25000
cl_cmdrate101
I have X4 AA and X16 AF with full hdr and the highest settings and I get 150-200 fps and 177 average fps with the video stress test.
potato28
8,964
Originally posted by: nib95
If your mate takes CSS seriously.
Then tell him to use as low a settings as possible in that game.
The higher the settings the worse your ping and hit registration.
false, unless running high settings gives you less then 100fps constant, that is the only time it would make your hit reg worse.
video settings won't affect pings though ;)
No, they do.
I've tried and tested enough times.
Going from max settings to low settings on the same server drops my ping by about 5-10.
Even when I'm getting 100+fps constant either way.
No they don't. Try playing on a few different computers, using the same keyboard and mouse. It's the internet connection that ultimately determines your ping and hit registration.
