FPS Dropping - Can't figure out why - Help?
Ne0m
This problem requires a little back story, so here we go, if you don't want to read it, summary below:
I woke up one day to find my computer frozen, tried to hard reboot, was sent to boot up menu, and no matter which option I picked, computer kept restarting. Figured my HD had failed, it was about 7-8 years old, went out bought a new HD and since I couldn't find old XP, bought XP Home SP2. Attempted to install windows on hard drive, didn't work, had to F5 at RAID F6 message and select APCI. Prior to the HD crash, I could play CS/WC3 with 99-100, and 50-70fps respectively, using a Nvidia GeForce4 MX 440. After reinstall, CS drops to 60 fps whenever I look where animations would be coming from, regardless if it's behind a wall (a la aim_ak-colt). Warcraft 3, fps dropped to low 30s and sometimes mid 20s. Went out, got a new gfx card, PNY Nvidia GeForce FX 5200. Tried both games, same results. I've used memtest 86 and ultimatebootcd to check both my RAM and my CPU, no errors. My 3d mark score was 84. Attempted to resolve all shown driver conflicts (in device manager)*, have tried reinstalling, have tried Windows, graphics card and performance tweaks to no avail. I'm stumped, any help would be much appreciated.
Summary:
-Woke up to frozen computer
-Wouldn't boot up, sent to boot up option menu, restarts regardless of choice
-New HD + New Windows XP Home bought
-Freezes at "Setup is starting windows"
-F5 hit, "APCI" chosen as opposed to "Standard PC"/Auto-detect
-Prior to HD crash, could play CS/WC3 quite well
-After install, FPS drops by 40 whenever there is high animation (even though animations have been set to lowest quality)
-Bought new gfx card, same results
-Tested ram, cpu - passed
-Attempt to resolve driver conflicts*
-Be sad
Computer Specs:
CPU: AMD Athlon XP 2200+ (AGE: ~6years)
MOTHERBOARD: Albertron KX400-8XV (AGE: ~6years)
RAM: (Forgot brand) 512 PC3200 (AGE: ~6years)
VIDEO CARD: GeForce 4 MX440 (Old, Age: ~7-8years) // GeForce FX 5200 (New)
WINDOWS VERSION: Windows XP Pro (Old) // Windows XP Home SP2 (New)
DIRECT X: 9.0c
VIDEO DRIVERS: Tried a variety, from old to new, currently running 91.47
SOUNDCARD: Creative SoundBlaster Live!
Harddrives: Maxtor 200 GB (Brand New - New boot)
WD 80 GB (Old, age: ~7-8 years - Old boot)
WD 250 GB (Age: ~2-3 years)
My guess, from things I've read leaves me with either an IRQ conflict, directx 9.0c conflict, or soundcard conflict. I hope I've been thorough enough, hope someone out there can help! Thanks.
* I went to Creative's site, and downloaded & installed the drivers. In device manager, the card shows up as "multimedia audio device," under "other devices," as opposed to the card name under the sound, video, and game controllers section.
btcomm1
943
What is left is your motherboard, perhaps your motherboard went bad. Maybe you could go to frys, pick one up and if it still doesn't solve your problem then post back and return the board.
Well your motherboard is pretty old so I don't know if you could get one locally but I think it's your motherboard, I mean it's not your windows install, it's not your graphics card, it's not your ram what else could it be? Perhaps your CPU but usually they don't go bad.
If you think it's a sound card conflict, remove your sound card and see if the problem goes away.
