Found why XP and my Geforce would not work together !
cotton
89
I would like to pass on the problems and fix, that I had when installing a Gainwood Cardexpert Geforce 3 card that only took me about 8 hours to find out the problem
I bought the above video card and installed a clean version of XP pro on my Asus CUSL2-C Pentium 3. After sucessfully installinig XP, I installed the latest drivers from Nvidia and did not install any of the Gainwoods programs that came with the card.
I then installed my DVD software (WinDVD) and tried a DVD. It locked up and XP rebooted on its own and when it restarted, XP gave me a message "it appears that your Nvidia drivers has caused a problem"
I then tried other Detonator XP drivers and same problem.
I then installed Max Payne and Unreal Tourn, and both games froze and XP rebooted and gave me the same message about Nvidia drivers causing the problem. I again tried other XP drivers and the games and DVD player froze.
SInce I had 98SE backed up an my second hard drive, I changed the ribbon to that hard drive, booted up and after the BIOS and memory check, the screen went black and and a small red square was flashing in the upper left corner and would not boot into 98.
The problem lied in the fact that I was overclocking the CPU (not the video card) I was running my P3 850 at 8.5 x 110
As soon as I reset the BIOS to 8.5 x 100 all was well, games and DVD in XP worked flawlessly, the hard drive with 98 booted up.
I hope that this helps some that may be experiencing problems with overclocking their CPU and running a Gainwood Geforce 3
TheJTrain
665
So were you using the latest Det4 drivers from nVidia, 23.11? Glad to hear you got it working, I'm just about to assemble a new system with WinXP and the Gainward GeForce3 (but I'm using an ECS mobo and Athlon XP).
Jason
Slogun
2,587
Just read your reply JTrain, and thought I'd mention that my components are similar to what you are building and hope you are as happy with them as I am.
TheJTrain
665
Hey sLOGUN - yeah, they're very similar (almost exact except for brand names on drives, etc.). It seems that from what I've read, the GeForce3/WinXP problems are sometimes caused by overclocking - if I can assume that everything's working great for you, are you overclocking the CPU or GPU? And what version of nVidia drivers are you using?
And do you mind if I use you for a resource when I start assembling (this weekend!)?
Thanks,
Jason
Slogun
2,587
I am using Nvida Win2K-XP_23.11 which work fine. I am not presently overclocking CPU or Vid card.
Feel free to contact me if you need any assistance while putting things together.
