- Jun 21, 2003
- 955
- 1
- 81
update: Searchmaster and dnetmhz both found the document.
The reason I was looking for it is I had a mole that was classified as dysplastic nevus. Its basically a sign that you are at risk for skin cancer. As the document states its unwaiverable. However, the document also shows that if you do have skin cancer and it is cured it is waiverable. This makes no sense to me. I went in for MEPS (Military Entrance Processing Command) for OCS (Officer Candidate School) and was denied by both the station and the higher authority (BUMED) for dysplastic nevus. I'm trying a few other avenues to see if I can possibly get waivered and this document may help.
Thanks again all!
I'm looking for a document that was originally found here:
147.248.153.52/robo/projects/cc_help/SkinDisorders.doc
The search terms I originally used on google were army, dysplastic, and nevus
I can now no longer find it on google, cached or otherwise and the internet archive doesn't have it either.
The document is called 'SkinDisorders' as you can see from above and I believe it was on a military server.
I appreciate the help. Thanks
Thanks again all!
