Directron now stocks a case similar to the Antec 10xx series case, except that this one has no door on the front. About the only other major difference that I have noticed, is that this one has only a single 120mm fan in the back instead of the dual 80mm fans. According to Directron, CompuCase is the manufacturer. Case specs can be found here.
Blatently ripped from Directron:
<< Charcoal black mid-tower ATX computer case. Model CI-6919BSH300AR-T. Made by CompuCase, it comes with 300W ATX HEC-300AR power supply. Upgrades are available as options.
Features & Specifications: Elegant outlook. Sufficient inner space. Four 5.25" external, four internal 3.5" and two external 3.5" drive bays. Seven expansion slots. Rear 12cm fan (optional), two front 8cm fan (optional) for thermal solutions. Front access 1394,audio,and USB ports ( need add connector and cable). Easy replaceable washable front access air filter. Dimensions: 8.25" x 18.50" x 21.25" or 210 x 480 x 540mm (W*D*H). M/B size full ATX, micro ATX, SIS. Horizontally mounted power supply allowing easy access to processors and memory. >>
