I got a Fortissimo II in order to run the digital out to my receiver for everything. No analog cables
It seems that I can choose to use the Digital out for either my Main sound (receiver sees as PCM) or as raw data from PowerDVD (receiver then decodes DD or DTS) , but not both at the same time.
Also, in order to switch between the two, it requires me to restart my computer ...
I dont know if there is a fix to either be able to use both at the same time (enabled at the same time, not outputing simultaniuosly)
or switch without restarting, but if there is..please let me know..
If there is no fix..does anyone know of a soundcard that will do this ? GTXP or Santa Cruz, maybe
I heard that Live and Audigy cards will only output digital to Creative digital speakers through some DIN cable, and it doesnt work
with Optical or Coax digital to a receiver.....
FIXED NOW with SB Live!
Well....the Fortissimo II was a waste...
I got my Soundblaster Live! Value to work the way I wanted
I bought a MONO mini to RCA jack at Radio Shack
and plugged that into the Digital out on the sound card
then I ran a Digital Coax cable from there to my receiver..
PCM out works great and RAW data out works great with WinDVD.
Guess I'm gonna take back the Fortissimo...I wonder why it requires a restart to go from PCM to Raw..pretty lame.
I still need a card with Digital In and Out..
I might try the Philips Acoustic Edge...anyone with experience on one of those ?
The normal Audigy or Santa Cruz doesnt have digital in and out unfortunately.
The Audigy Platinums do , but for some reaon they put all the connections on the front which is wack.
Hercules Fortissimo II and GTXP are out because they require a restart to switch from PCM to RAW.
