Formatting problem
Sgt Pepper
93
I'm trying to format a hard drive and I keep getting the error:
Trying to recover file allocation units
I tried to first fdisk the drive then recreate the partitions but that didn't seem to fix it.
Cnuke
186
I have had this exact poblem. At the a:\ type fdisk /mbr
this comand will repair the master boot record. That was my fix. After that delete all drives in FDISK and recreate them. You should be on your way.
Good Luck
Cnuke
snowyowl
21
If you had a linux partition or other non dos partition...you may need to try what cnuke said to fix the boot record.
