Formatting a SCSI Drive in DOS.
Abj
30
Hi, i just got my new system. It's got an IBM 36LZX drive and a Tekram DC-390U3W controller. I managed to create partitions using the tfdisk utility supplied with the controller, but i can't get the drive to format. The Tekram manual says i have to use the regular dos format utility to format the drive, but that doesn't work. It says the driver returned invalid drive parameters, and then quits. I'm really frustrated, i have a brand new system waiting to be used, but i can't do jack! Any help would be greatly appreciated.
Walk
21
How are you booting the system and with what OS? 98? 2k?
Maybe you are booting with and old DOS or Win95 diskette that doesn't recognize drives larger than 2GB? You'll need Win95-B or Win98 at least in order to format that drive.
Abj
30
I'm booting of a bootable disk made in Win98. I can't just boot of the Win2K CD, as it gives me an error saying there's no temp. space, and exits. The device ID's are fine, and cables are terminated. Anything else i'm missing ?
Abj
30
Okay, i took the drive and card to a friends place, formatted it, copies system files etc. But when i came back and put in my system, the drive gives and invalid media type error! I'm at my wits end. It's getting detected fine, i'm using the latest scsi drivers, everythings seems okay, it's just not working.
Trashman
2,040
sounds like termination...if it just worked at your buddy's and not on yours.....whats different from your bud's setup and yours?... are you usin a 80 pin adapter...are there any other devices on your system??
mandrake88
78
do you have the tekram drivers in your floppy?? and make sure they are also defined in your
autoexec.bat and config.sys files (both for dos only). if not it will not be recognized..
creating a start up disk from win98 does not place the drivers to the floppy you have to do it manually.
good luck.....
Abj
30
Actually i used my own controller at my friends place. Just plugged it in, installed Win98 drivers and formatted it, so there's not question about termination, or controller card settings etc. I am loading the aspi and symdisk drivers during bootup from my config.sys, it does recognize the drive and assign it a letter, but it won't let me read the drive. What do i have to load from autoexec ?
