Despite an inclination to label even myself a computing hardware moron, I have managed to render 2 Western Digital 160GB's totally unaccessible. I now need some advice from the guru's...
I formatted this drive and the one that crashed before it in command prompt DOS mode, after FDISKing it using a Win98 Boot Disk (I used command prompt within XP safe mode command prompt because it allowed me to FORMAT D: /FS:NTFS). Everything went fine, I started backing DVD's up on it... and after about a month, it simply says D: is not accessible (on 2 drives now, same situation). Might there be other software or hardware issues causing the drives to fail? Should I have formatted differently? Or do I simply have bad luck with hard drives lately? I have an IBM 120GB that has never failed me in the many years that I have used it... but I tried an IBM 180GB without success (error at end of format), so I decided to go for a WD. Thanks in advance for your suggestions... I can't afford to keep losing data as these damned things crash on me.
Ryan
Ryan
