Originally posted by: dl5175
Will I need one to install bios or will I be able to dl and burn bios and drivers to cd with my other system?
You won't need one to "install" BIOS. That will be there. You may need one if you have a SATA drive.
But if you purchased Windows XP, the disc is most likely SP2 and you should be ok.
Depending on the MOBO ( Motherboard ) you can use a bootable CD or USB flash drive.
Originally posted by: Kensai
It depends on the motherboard chipset. If it's one based on the nForce 3 or nForce 4 chipsets, you don't need a floppy to install on an SATA drive, only when you're attempting a RAID.
Originally posted by: YOyoYOhowsDAjello
Is there a floppy in this system you're typing on? If you can, just take it out while you use it for the SATA drivers and then put it back.
Does it matter how old the system is?
A floppy drive is a floppy drive. If it works with normal 3.5" floppies, it will be fine. Sounds like you might not even need it though 🙂
Read this too
