I was hoping some of you guys might be able to point me in the right direction
I have a 98 Tarus with 247,000 miles on it
When I try to start the car it tries to start, but the engine does not turn over. It does not appear to be a battery issue. I am guessing that either the spark is not there (therefore being a distributor cap issue right? I am thinking this as I have not had problems starting it before and it seemed to be running fine. I am guessing if there were spark plug issues I would have noticed some starting problems prior to this) or a fuel issue.
Does anyone have some insight? Is it easy to check the distributor cap? (Keeping in mind that we just got 7" of snow and I have no garage)
The engine was replaced at 147,000 miles due to a cracked engine block
The fuel filter was replaced 7,000 miles ago
The alternator was replaced 27,000 miles ago
I do not know about the fuel pump
There is at least half a tank of gas in it. I filled up 3 days prior to this issue
Thank you for any replies!
