The problem is I can't even install it. An error message shows up that the software couldn't detect compatible hardware. What's up with this? I uninstalled previous driver before trying to install 77.30.
Looks like the Go 6600 isn't listed in the nv4_disp.inf file, nor is it listed in the readme file that comes with the drivers. That's why they won't install.
The mobile nVIDIA chipsets aren't supported by the standard Forceware releases. You have to get drivers specifically for the GeForce Go chipsets (usually through the system vendor) or get the modified versions available on sites like http://www.laptopvideo2go.com.
