I was wondering when abouts you guys could no longer use default voltage during your overclock. Right now, when I set to 200fsb, I have to up the voltage from 1.5V to 1.60V while lowering the multiplier to 10.5. Should I also max out the Northbridge voltage? I have no clue when to judge when the NB needs more voltage. Also, for this board and processor, is it feasible to obtain FSB 216, Multiplier x11 with CPU voltage not exceeding 1.75V? I know every chip is different, but I just want to see what people have been able to do with air cooling.
In addition, after I make a change to my FSB and Multiplier, and voltages, I usually cannot boot. I get no signal to my monitor, and only after turning off my power supply for 15 seconds - I try to boot and the BIOS tells me "CPU is unworkable, or an unappropriate change has been made." I dont really use "out of the world" voltage and FSB/multiplier settings, so Im not sure if this means I have a damaged cpu or something. After the latest bout, I changed the multiplier down from 11.5 to 10.5 and raised the voltage to 1.6V and maxed out the NB @ 1.7V with FSB at 200 ~ so far no problems. Is this were my overclocking ends? or is there hope for more overclocking?
My ram is Mushkin PC3500 Level 2 (2x 512MB)
My HS is the Coolermaster Aero 7+
Thanks in advanced!
Thanks in advanced!
