For those with a Philips monitor
Booster
4,380
I got nothing against the cool Lightframe feature Philips monitors support (I got the one that does Lightframe 3), but somehow there is one bug I can't get over. I install the software under my Windows XP SP1a OS, but remove it from Startup menu b/c I only use the software at times (when looking through my photos mostly), launch it with a shortcut. But I also get frequent Internet Explorer crashes when the Lightframe isn't loaded. This I can't understand. It just displays an error message of a conflict with an addon of that proggie. I uninstalled the thing, and everything came back to normal. Then I downloaded the latest version from Philips website - the same bug appeared.
Had to uninstall the program b/c I can't browse the web when it's installed. But I'd like to use it. Any tips? Have you encountered the same issue?
Thanks in advance for all replies.
JBT
12,094
I have a Philips 109B I havn't used the light frame program in along time. I will try to load up the newest one u say 3.0 toamrrow and see if it has the same behavior as you are discribing.
