sweetrobin
- Jan 20, 2000
- 1,184
- 0
- 0
okay .. here is your pricing ... rings ... gold is the cheapest, white gold is slightly more expensive, and then platinum is even more so. Most good Jewelry stores will give you one free sizing when you buy a ring from them. Find a ring you like buy whatever size they get it in and then give it your girl. Then if it doesnt fit ... take her to the store to get it sized ... If you buy it else where .. the resizing of a ring is not terribly expensive . My engagement ring ( a family heirloom in E's family ) had to be sized up 2 and a half sizes and it only cost us $36.00. Its a diamond surrounded by sapphires (the stone for September which is when we are getting married) and the band is white gold. I personally like white gold alot better than yellow gold.
