For Overclocking, Would this Power Supply cut it?
thatsright
3,004
Need help from those in the ?know? Just wondering if this Antec True Power 380W Power supply would be enough to cut it with the components I?ll be running below. AND PLEASE NOTE: I definitely plan on Overclocking my P4 CPU.
My new Rig:
-Abit IC7 MB Canterwood
-P4c 2.4Ghz OVERCLOCKED Retail version with supplied Intel HSF combo.
-512MB OR 1GB of DDR Ram suitable for stable Overclocking (Depends on budget as to how much I?ll finally get)
-ATI Radeon 9500 Pro Retail ? Non-overclocked
-WD 120G ATA100 w/ 8MB Cache Caviar ED
-Maxtor 60G ATA 100 w/ 2Mb Cache (from old sys)
-Seagate 6.4G ATA 66(?) w 2Mb Cache (from old sys-and ready to die any day now. Right ;-)
-16X DVD-Rom (Sony or Lite On? Will buy)
-52X TDK VeloCD-RW Drive (from old sys)
-SoundBlaster Live Original w/ Digital riser card (from old sys)
-D-Link 10/100 NIC w/ WOL (from old sys)
-Panasonic or Samsung 1.44MB Floppy Drive OEM (Will buy)
This is all of the hardware that will be inside the case, hooked up to the PS. Do you think it would cut it with ?only 380 Watts, and also with me attempting to O?C my new P4c CPU? I want to get at least 3Ghz in a O'C attempt, maybe a BIT more; like 3.2 or somthing. But I'm not that greedy about it
I ask if the Antec True Power 380 is up to task, as I want to buy the Antec Sonata case, and it comes with this PS. I was going to buy a Antec 430 PS for my new system, but im just wondering if the TP380 would be just as good for the above and my Overclocking?
Opinions, please.
Thanks
BG4533
1,892
I think you should be fine. The Truepower PSUs are really hefty and handle much more than the average. The 430W would probably be a better choice if you were buying it separate though, it would give you a bit more headroom.
Brian
