For contact lens, is it ok to vary Base Curve by .1 for astigmatism?
Techie333
2,368
I have astigmatism and I want to order a pair of lens but the BC (Base Curve) varies by .1 so I'm not sure. My prescription BC is 8.7, the one I want is 8.6.
tami
11,588
i'm still not sure what the base curve is (OP, care to explain? i've been looking for answers for a long time!).
my normal base curve is 8.8. i wanted to try acuvue hydraclears and the only ones available had a BC of 8.7. i went in for the plunge and the contacts were great.
Techie333
2,368
base curves only vary for people with astigmatism...i think...im not sure...it's should be on ur prescription
Eli
Super Moderator | Elite Member
8
It's fine.
I'm not an optometrist, but I did stay at a holiday inn express last night.
isasir
8,609
1. Contact Lens Base Curve
Base Curve, or BC, values range from about 8.0 to 9.5. The doctor fits the lens with the curvature most appropriate for your eye. Most disposable contact lenses come in several different base curve values. If your prescription does not contain a base curve value, this is likely because your brand of lens only comes in one base curve.
base curve values are a bit like clothes sizes - just because you are a base curve 8.6 in one brand of contact lenses doesn´t mean you will be in another.
Teh google
Shlong
3,130
59
My original prescription was BC 8.6 but I bought some contacts using BC 8.7 & didn't notice a difference.
tami
11,588
Teh google
i couldn't find a definition that i could understand (too much opthamologist-babble). that one above definitely helps. thanks. :)
