For anyone having multiple optical devices and 1 input...
Bacstar
1,273
30
I only have one optical input on my receiver which I'm using with my Xbox360. Now, I'm adding a PS3 into the setup which has an optical out as well. Has anyone tried using a splitter yet and had any problems going this route?
http://www.amazon.com/gp/product/B0002MQGR2
Update1: The splitter didn't work. I only got one side of it to work. However....after taking it apart, I was able to use a few pieces to jimmy-rig the cables so I can at least interlock each end as needed when I switch between the PS3 or the Xbox. It's kinda funny. It looks like two fishing lines jammed into one fitting.
Update2:
Found a device that works like an HDMI multi-port switch but for optical devices... So if anyone is in the same predicament, hope this helps...
http://www.inday.com/da4x/da4x.htm
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
I believe this is designed to take one output to two inputs as stated here
http://www.monoprice.com/produ..._id=966&seq=1&format=2
(similar if not the same product)
But if you have the right kind of devices, it would be able to work in your case too. Check out the Amazon reviews. If your devices stop sending any sort of optical signal when not in use, then it might work for you.
There are enough negative reviews of this product that I think you should consider using something else.
An optical switch would do what you want it to do.
Bacstar
1,273
30
I didn't read all the reviews, but it seemed most of the problems were with devices that kept putting out a signal even if the device was turned off. The PS3 and Xbox get turned off when one or the other isn't in use. It's also the kind where i don't have to get up and flip or turn a switch which I'm a firm believer in the more moving parts there are, the quicker things break kinda crowd. Plus for the price, it's worth a shot. I could always try something else if it doesn't work.
Edit: I'm also open to other solutions or suggestions...short of buying a new receiver :)
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
As long as you've checked that the optical signal cuts when the device is off, then it seems like you would be good to go if the thing works.
Modelworks
16,240
7
It will work, just don't try to run the cables too far.
Any time you couple or split an optical signal there is loss.
I don't know exactly how much, but as long as the cables are kept kinda short you should be fine.
Bacstar
1,273
30
Good to know. I ordered a pair of the shortest i could get away with (1 meter each). I'm kinda worried about the one I currently have when I initially got the xbox which is probably a 6 footer, so we'll see how it goes.
thecoolnessrune
9,673
583
I use one with a 6ft. length going into my receiver. No loss problems at all. Heck, one of my inputs is a 30ft. run. No problems at all.
Modelworks
16,240
7
16 feet or so is the max for the spec.
I wouldn't recommend anything longer.
it will probably work, but if it doesn't you can't really complain.
