Question For an external spinning disk backup drive, any point in going beyond USB 3.0?
33,950
I'm replacing my backup drive. My new computer has Thunderbolt 3, USB 3.1 gen 2, USB 3.0, and USB 2 ports. Seems pointless to buy a drive with ports that are much faster than the enclosed drive can read/write the data. Thoughts?
Insert_Nickname
4,971
1,695
If you're using a HDD-based external drive, there is no reason to go beyond regular 5Gbit USB3(.1/2/whatever). Its more then enough for any HDD or two.
If we're talking SSDs, it becomes a bit more complicated. For a standard SATA3-based drive, 5Gbit USB3 is still -enough- with UASP support, as it tops out at about 450MB/s. The performance improvements with 10Gbit USB3 are negligible. You only get 500-520MB/s with it. It's only when using an NVMe-based drive or RAID array 10Gbit USB3 begins to shine.
10Gbit USB3 is also notoriously pickish with regards to cable quality, you shouldn't expect a cable run of more then about a metre without a really high quality cable.
Shmee
8,226
3,131
Yes but some HDDs are faster than others. If you don't want slow backups, get a quality backup drive. I would avoid the cheap ones without actual SATA connections.
