Fop38 without fan test
EJ
99
I found out too late that the fop32-1 was the same heatsink as the fop38 but just had a quieter fan. I knew before I bought the fop38 that I was going to replace the fan on it. Anyway, being that I didn't have a replacement fan yet I decided to take off the fan(before I went nuts and stuffed artic silver in my ears) and let my cardcooler XT try to cool it.
P3 - 933
Golden orb - 32 idle , 55 full (stable)
Fop38(w/evilfan) - 31 idle, 38 full
Fop38 no fan (card cooler XT) - 31 idle , 43 full
43 degrees isn't so bad considering I was at 55 with the golden orb. Now I'm going to try 1000+ ;).
EJ
EJ
99
Any reason why?
I touched the heatsink while at full load at it was only slighty warm where the fan wasn't reaching as good. I usually disable the fan blowing across the cpu when there's a fan on the heatsink anyway. I also heard that the temp difference is 5 degree's between the y-tech fan and the one the fop38 had on orignally. So I don't think that'd help.
The fan could die but I have a temp alarm on the cpu. Hopefully it works :)
EJ
EJ
99
I think you're right. Gets a little unstable in games at full load at 43 degrees. Funny how the temp is 55 on the golden orb but it's stable in games at the cpu temp.
Guess that's why you shouldn't test heatsinks in cases but outside on a plate like some of the reviewers do.
EJ
