Foobar 2000: Where is the volume control?
clarkkent333
1,024
I checked out the FAQ and couldn't find this. I downloaded the special installer, installed all the options and everything went smooth. When I open it up I have no way to control the volume. I checked out the options and it says I have volume control installed but Im getting nothing. Anyone know how to do this? Thanks.
Andvari
612
Originally posted by: clarkkent333
Is there no visual volume slider or measure like in Winamp?
Not that I'm aware of, unless you find a skin or something perhaps. There is a dB display in the bottom right, but that's it. I never need volume control/sliders anyway, I almost always like to listen to programs set at max volumes, and just adjust my hardware. So even for the dB display, I disabled that. :p
konakona
6,285
use replaygain to even out volume level between tracks/albums and you wont see much use for software volume control. dont forget it comes with clipping attenuation as well.
