Fonts way too small in 98% of windows
A possibility: Right click your desktop, select Properties and select the Appearance Tab. What is the fot size? (You may have set the font size via Themes too.) Also in the same Display Properties panel, select the Settings Tab, select the Advanced box and check what you have DPI set at.
Display setings change if you use Windows Classic Settings or not. For more info, open Help, and search on "display font".
Finally, you may have hosed a system font by renaming it, installing a font with the same name or other methods.
Good luck!
