Folding@Home transmission error
Uppsala9496
5,272
19
Core 1 of my main rig is having some issues transmitting completed work:
[03:49:29] Folding@Home Gromacs Core
[03:49:29] Version 1.90 (March 8, 2006)
[03:49:29]
[03:49:29] Preparing to commence simulation
[03:49:29] - Looking at optimizations...
[03:49:29] - Files status OK
[03:49:32] - Expanded 2997056 -> 16578185 (decompressed 553.1 percent)
[03:49:33]
[03:49:33] Project: 2417 (Run 9, Clone 84, Gen 0)
[03:49:33]
[03:49:34] Assembly optimizations on if available.
[03:49:34] Entering M.D.
[03:49:56] (Starting from checkpoint)
[03:49:56] Protein: p2417_Ribo_Cl
[03:49:56]
[03:49:56] Writing local files
[03:49:56] Completed 105000 out of 250000 steps (42)
[03:50:00] Couldn't send HTTP request to server (wininet)
[03:50:00] + Could not connect to Work Server (results)
[03:50:00] (171.64.65.65:8080)
[03:50:00] - Error: Could not transmit unit 01 (completed March 30) to work server.
[03:50:00] + Attempting to send results
[03:50:00] Extra SSE boost OK.
[03:50:35] Couldn't send HTTP request to server (wininet)
[03:50:35] + Could not connect to Work Server (results)
[03:50:35] (171.65.103.100:8080)
[03:50:35] Could not transmit unit 01 to Collection server; keeping in queue.
[03:50:35] + Attempting to send results
[03:51:16] Couldn't send HTTP request to server (wininet)
[03:51:16] + Could not connect to Work Server (results)
[03:51:16] (171.64.122.141:8080)
[03:51:16] - Error: Could not transmit unit 02 (completed April 2) to work server.
[03:51:16] + Attempting to send results
[03:51:58] Couldn't send HTTP request to server (wininet)
[03:51:58] + Could not connect to Work Server (results)
[03:51:58] (171.65.103.100:8080)
[03:51:58] Could not transmit unit 02 to Collection server; keeping in queue
Core 2 of my machine is working just fine.
[07:07:29] + Attempting to send results
[07:10:51] + Results successfully sent
[07:10:51] Thank you for your contribution to Folding@Home.
[07:10:51] + Number of Units Completed: 5
Should I just delete the 1st core and reinstall? I hate to lose 2 completed units, however that core is only working on unit 3 while my second core is on unit 5.
GLeeM
7,199
128
No do not delete them, at least not yet.
Did you try stopping and restarting that client?
Another thing that might work is to use a special shortcut just for sending results.
Make a shortcut to the client and in the Target textbox of Properties add the following: " -local -verbosity 9 -send all" without the quotes. You have to stop the client before using this shortcut.
If that doesn't work, there is a program that can sometimes fix a problem. The name is "qfix.exe" and can be found at the folding forum, if you need it I can probably find the page.
It is not unusual for the two cores to get different WUs. The first probably got a couple long WUs.
Have you considered trying the Win SMP or Linux SMP clients. They are still in open beta, but you only run the one client and it will use up to four cores. It gives better points per day (ppd) than two regular clients.
Uppsala9496
5,272
19
GLeeM, I tried adding the "-local -verbosity 9 -send all" flag and had no luck.
[15:16:24] + Attempting to send results
[15:16:24] - Reading file work/wuresults_01.dat from core
[15:16:24] (Read 8082962 bytes from disk)
[15:16:57] Couldn't send HTTP request to server (wininet)
[15:16:57] + Could not connect to Work Server (results)
[15:16:57] (171.64.65.65:8080)
[15:16:57] - Error: Could not transmit unit 01 (completed March 30) to work server.
[15:16:57] - 31 failed uploads of this unit.
[15:16:57] + Attempting to send results
[15:16:57] - Reading file work/wuresults_01.dat from core
[15:16:57] (Read 8082962 bytes from disk)
[15:17:32] Couldn't send HTTP request to server (wininet)
[15:17:32] + Could not connect to Work Server (results)
[15:17:32] (171.65.103.100:8080)
[15:17:32] Could not transmit unit 01 to Collection server; keeping in queue.
[15:17:32] + Attempting to send results
[15:17:32] - Reading file work/wuresults_02.dat from core
[15:17:32] (Read 8719971 bytes from disk)
[15:18:09] Couldn't send HTTP request to server (wininet)
[15:18:09] + Could not connect to Work Server (results)
[15:18:09] (171.64.122.141:8080)
[15:18:09] - Error: Could not transmit unit 02 (completed April 2) to work server.
[15:18:09] - 13 failed uploads of this unit.
[15:18:09] + Attempting to send results
[15:18:09] - Reading file work/wuresults_02.dat from core
[15:18:09] (Read 8719971 bytes from disk)
[15:18:50] Couldn't send HTTP request to server (wininet)
[15:18:50] + Could not connect to Work Server (results)
[15:18:50] (171.65.103.100:8080)
[15:18:50] Could not transmit unit 02 to Collection server; keeping in queue.
[15:18:50] + Sent 0 of 2 completed units to the server
[15:18:50] - Failed to send all units to server
[15:18:50] ***** Got a SIGTERM signal (2)
[15:18:50] Killing all core threads
I found the qfix in the folding forums. I'll give that a try. Once again, thanks for the help.
CupCak3
1,318
Are you sure a firewall isn't blocking the transmission?
I agree w/ GLeeM on possibly giving the SMP clients a try. You'll appreciate the better PPD :)
Uppsala9496
5,272
19
No firewall issue. Core 2 had no problems transmitting.
I'll give the SMP a try.
Insidious
7,649
make sure you stop your other clients (and don't let them re-start/remove as service if you have them istalled that way) before you install the SMP!!!
-Sid
GLeeM
7,199
128
With my firewall, Zonealarm, I have to give the OK to every client.
Couldn't send HTTP request to server (wininet) - this indicates that the client cannot even send a simple http packet.
Double check the firewall ;)
