Folding@Home on Windows 7 64-bit using a GeForce GTX295. Solution found.
Keysplayr
This, was a pain. Much trial and error. So I’m writing this up to ease the pain for others trying to do it.
If you have F@H GPU installed, then uninstall it. We will do a fresh install after preparing the system.
What you’ll need.
A computer (hehe)
Windows 7 64-bit (I have not tried this with Win7 32 bit and don’t have the slightest clue if this procedure would be any different, or identical.)
A GTX295 with the latest Forceware drivers installed.
A second monitor (if available).
If no second monitor is available, we can use a DVI dongle that comes with your card.
To prepare the DVI dongle (if used) you’ll need 2 68ohm resistors (radio shack carries these in packs of 5 for a buck.)
The resistors are used to “fool” Windows into thinking there is a second monitor plugged into the dongle.
They are installed as follows:
This represents the D-Sub end of the DVI dongle. The resistors should be used as jumpers. The pin holes we are using are 4 & 9, and 5 & 10.
Use one resistor, bend one end of the wire around to make a very tight “U”. Snip the longer wire to even the length to the shorter one. Insert one wire into pin hole 4, and the other into pin hole 9. That’s the first resistor. Repeat this for pin holes 5 & 10. Make sure the resistor wires do not touch one another.
With the computer off, install the DVI dongle onto the 2nd DVI port on the GTX295.
Fire up the computer.
Go into the Nvidia Control Panel. Make sure that PhysX is “Disabled” and Multi GPU is “Disabled”. Save settings and exit.
Right click on the desktop and choose “Personalize”.
Choose “Display Settings”. You’ll notice the option now to extend (Important!! EXTEND” the desktop to second monitor. Set resolution for both. Apply and Exit.
Install Folding @ Home GPU client and follow Stanfords Multi GPU installation instructions to the letter.
Fire up each client separately and configure them to Stanfords instructions.
Close both instances of F@H.
Nvidia Control Panel. Enable Multi GPU but leave PhysX off. Save and Exit.
Remove DVI dongle.
Start F@H GPU1 client.
Start F@H GPU2 client.
Only after tricking the system, and enabling MultiGPU in Nv control panel, AND removing the DVI dummy dongle, did both GPU cores on the GTX295 start cranking out 7500+ PPD. Before that, it was either one core working or the other. Never both.
Anyway, I do believe that if you shut your machine down, you’ll have to go through the MultiGPU, Extend desktop, Dongle Dummy procedure again. Windows will redect things when rebooted.
So, this might be a pain, but it’s worth all the aggravation (mostly mine) to get this kind of production out of one GPGPU multicore.
I’m posting this as a rough draft so those who understand it can get started.
I’ll neaten it up as time permits.
If anyone doesn’t understand something, or I explained it poorly, please notify me and I’ll try to make it more sensical.
GOOD LUCK!! 
Thanks Keysplayer for your time on this 🙂I think things will be similar on Vista, it is WinXP that is a little different.
Well...at least this ans my question of F@H working with Win7.
I built a Phenom II 955cpu/Zalman 9700 heat sink/EVGA 250 1gig/Giga 785 mobo/4 gigs corsair/500 gig Hard Drive in a Antec 900 box. After a few days of it not even doing a post and stripping it down to its knickers to work (repositioning the mems did the trick at last - weird) I attached it to a Sony Bravia XBR 40 LCD via the 15 pin port (it REALLY looks great on that screen! - tempting) I moved it back to the living room where the other boxes are at. Attached it to an Acer 22" LCD but discovered that my 4port KVM box would not let the mouse work via USB (Arggh!!!). Brought from work my MS keyboard & Logitech track ball to get it to work after using it with the Bravia hookup.
First program after Win7 install was F@H GPU command prompt and it ran (about as fast as my other box, an intel 6600 quad cpu/w an 8800gt card) the program for about 3 sessions until it somehow quit after doing in the teens of session #4 while I was at work.
Looked at explorer and thought the folder was there the executable was missing!
D/L the systray version and opened it to run but no work was done and looking at Explorer again the only thing that changed was that the date of the folder was updated to the systray try.
Most percular...
Turtleblue
