Focusing on World Community Grid
Does it matter what project we work on in WCG? Or do all of the projects (such as GO Fight Against Malaria) contribute to the same count in WCG? I never know what to crunch under such as Computing for Clean Water.
Atleast my experience is that all of WCG's sub-projects gives roughly the same credit/hour as the other sub-projects, atleast under windows, but some does claim linux has an advantage for a couple of them while windows has an advantage for atleast one of them. Still, my recommendation is to run whatever sub-project-mix you want yourself.
But, Clean Energy Project 2, CEP2, does need some special considerations. For one thing CEP2 has fairly large uploads, so if you've got any form of monthly transfer-limits or something it's probably not for you. Another thing is that checkpoints in CEP2 is few and far between, if not mis-remembers have seen over 8 hours between checkpoints on an i7-920, so any computer that's often re-booted or something should not run CEP2.
Also, CEP2 is very demanding on the disk-system. The size on disk isn't the problem, even it's around 700 MB per wu. It's the huge amount of files and that even there's a long time between checkpoints CEP2 is nearly continuously writing to disk that is the problem. This means that if you tries to run "too many" CEP2 at once, there's a very good chance you'll hit the dreaded "No heartbeat for 30 seconds", something that means that ALL WU'S in memory will be re-started from last checkpoint. With the multi-hours between checkpoints even a single such re-start will lose many hours of crunching. :sad:
So, if your BOINC data-directory isn't running-off a SSD, my recommendation is to limit CEP2 to maybe 4 wu's at once, something that is configurable among the WCG-preferences on the web-page.
BTW, the default CEP2 is to limit to a single wu at once, so always remember to increase this a little if you want to run multiple CEP2-wu's.
Added some 32 cores to WCG, as promised. 🙂
Awesome! Thanks Peter.
Picked up a new CPU, mobo and RAM bundle today! My new toy that will be strictly used for DC. Still missing a few items to get the build going but hoping to get it going sometime in the coming week.
Nice! I wish I would have taken a couple of camparison pictured, but like Uppsalla I did some cooling upgrades today between the race and committing to other projects. An old Alpine Cooler Pro 7 on the 960t, tested and cranked up to 3.3ghz (fsb for the northbridge speed up) and six cores, an awesome and silent Cooler Master 212+ on the 1090t which I need to explore the limits of at stock voltage...
Anyway, 8 cores on WCG indefinitely (1M points), as promised 🙂
Thanks Blckgrffn! With your cores and Peter's, the journey to the top 100 will hopefully come sooner!
I need a cooler for the 2500k will probably slap on the 212+. They perform well in cooling the hotter running AMD chips in my fleet so I don't anticipate any issues with a 2500k which are cooler chips to begin with.
Mounted the 212+ today and quickly fired it up to make sure it POST. 2500k idling at 25C in the BIOS screen so I will assume the mount was proper. If I have time tomorrow, will throw everything else into the case, install Windows and test to make sure everything is stable at stock. If all goes well, hoping to have the CPU overclocked and crunching WCG by Friday.
The points keep rising ... 🙂:
Jan 26: _ 4 355
Jan 27: _11 224
Jan 28: _ 2 017
Jan 29: _45 005
Jan 30: 128 169
Jan 31: 160 760
Looks good! Lets hit milestones!
Good to hear about that 2500k, Zip. I am pretty sure it is going to be a great asset in your crunching endeavors. The 212+ seems to be a really nice air cooler, and I am impressed by the ability to scoot the fan up a bit if it conflicts with the RAM. I actually have mine pointing up as the CM Elite 371 is basically open on top and it seems natural to push heat the way it wants to go anyway...
And about the number of cores in play, I lied. My Dad's 2500k is crunching WCG as well, for a total of 12. That Sandy Bridge continues to surprise me with how much work it can get done for its power envelope. I like supporting AMD but a tip of the hat to the folks @ Intel...
http://boincstats.com/stats/overtake_stats.php?pr=wcg&object=team&id=16700
It's going to take a while but should be quite doable 🙂
The current top 20 producers based on yesterday's data. Peter is nipping at my heels!
I'm super excited to get that 2500k rig going. It's killing me that it's just sitting there! Is your dad's 2500k overclocked or stock?
Zip, why don't you use the 2500K as your gaming CPU and use the 4GHz i7 950 for WCG? The 950 is no slouch in WCG.
The 950 is running WCG currently. As is my HTPC and work computer. 😀 Basically every rig in my sig is on WCG except cruncher 1 which is on F@H.
Cranked all the way up to 3.4 Ghz 😛 It's my Dad's computer, so it just has to work.
I did bump up the 3 core turbo to 3.6, 2 to 3.8 and 1 to 4.0.
I want to get one and go for ~4.4 and get an extra cores worth of work out of it 😉
Yesterday evening I added 8 more cores (FX8150@4.2GHz) to WCG. OTOH: My quad-core Intel just broke down - onboard GPU-problem ... 🙁
Part 1 == Awesome - I'll be very interested in reading about how that performs.
Part 2 == Doh! Core 2 based then, I take it? Still, unfortunate...
Started stress testing this morning on my 2500k. Passed stress tests at stock settings so I cranked up the overclock to 4.3 GHz. Computer blue screened after 10 minutes. Bumped up voltage a couple notches and so far so good! Fingers crossed.
Once the SIMAP units run dry in the next 3 or 4 days, I'll have all 29 cores back on WCG.
Going to get ambitious soon and start messing with the overclock on the fx8120.
Good to hear! Looks like our team has some really solid support for WCG so hopefully we can start climbing them charts!
How's that 2500k @ 4.3 doing? 🙂
Just finished testing and success! 4.3 GHz stable @ 1.35V. Temperature peaks in the mid 60s and usually hovers in the low 60s. Might be able to get in the high 50s with a better cooler but I'm not going to complain with the $25 I spent for the 212+. I have a few spare fans and will mount a second for push-pull when I get a chance. Should be good for a few more degrees C.
Passed Prime95, LinX and Intel Burn Test with flying colors. I just have to install a few more things including BOINC and then off it goes with the rest of my rigs in WCG.
The FX hasn't been too bad. It's hard for me to really compare since it went on an existing machine which already has a lot of points in various projects. It would be nice to compare it with one of my X6's on a project with 0 points to see what it looks like after 24 hours or so.
Might have to sacrifice a day and do that. Any suggestions? I already have run or am running primegrid, wcg, correlizer and simap.
Oh, and I just swapped out the X3 machine with the X2 555BE. Testing at 3.7ghz now on all 4 cores. Being cautious with this one since it is the horrible rev 4.0 gigabyte GA-78LMT-S2P motherboard (gigabyte sent me a new board after I talked to them about the fried rev 3.1).
