Foam for Seagate HD RMAs?
weeber
432
Originally posted by: Tu13erhead
Originally posted by: weeber
Wag,
Do you have any other hard drive boxes sitting around? When I had to RMA a Seagate hard drive, I just happened to have the box that Maxtor sent me from a previous RMA for them. It had two plastic pieces that completely surround the hard drive. The box perfectly fit this assembly so that there was absolutely no movement. I just scratched out the "Maxtor" labels on the box and sent to Seagate this way. They sent me a new drive, no problems.
I went throught the same thing as you when I read Seagate's requirements. And you're right they want it sent back in a better condition then you received it. However, I just said screw it, and sent it in this way. They took it, so it could be another option.
Where'd you get the box from Maxtor? I have a hard drive of theirs to RMA...
The box I'm talking about is what Maxtor sent me for a replacement hard drive from a previous RMA. For the life of me though, I cannot remember what kind of packing I sent the broken Maxtor hard drive in.
eelw
9,526
4,723
Why don't you get them to advance exchange a replacement to you first and then you ship back the defective product in the box that you received? Yes, you need to provide a CC number, but you don't get billed.
Viperoni
11,084
Even if you use the bubble wrap with the bubbles that are like 1/4" in diameter... 10 layers would still provide the same protection as the foam they usually ship drives with. With the bigger 1" bubbles, 4 layers would be good.
Only thing is to make sure that the drive doesn't slide out the side of the roll of bubble wrap.
Wag
8,286
4
According to the CSR I spoke to there's a $25 service charge.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,591
You are spending more time asking for advice than taking it with some common sense.
