fmi power supply 500 watts for my 8kha+
bdyeager
160
good idea or not?
1700+
8kha+
sb live platinum
radeon aiw
a95f viewsonic
hp 882 printer
hp 4470c scanner
creative inspire 5.1 5300
logitech cordless keyboard
logitech cordless optical usb mouse
thermaltake dragon orb3+ with arctic silver
wd fire wire card with sony camcorder
linksys ethernet card
ibm 60gb 7200 rpm
pioneer 16x dvd
plextor 16 10 40 rw
usrobotics hardware voice/fax modem
4 port entrega usb hub
4 port linksys router
motorola surfboard cable modem
500 watt comp usa psu
fuji digital camera usb
512mb crucial ram pc2100
windows xp home
tboneuls
Banned
Nov 17, 2001
384
Personally, I would go with an Antec 400 watt power supply. I would also look at the soltek SL-75DRV4 (It think thats the ) and a slightly larger fan like the Ord 6cu+. You can't over-cool. And you may consider waiting for some KT333 boards.
zodder
9,543
www.jpcompservices.com
Great mobo choice. :) 500W may be a little overkill, tho. I have a similiar power requirement setup, and my Antec PP403X is more than enough. If anything, the voltage mod for the 8KHA+ would be a better choice than a more powerful PSU if you are going to overclock.
