FM2+ motherboard compatible with Seidon 120v cooler?
3derpderpderp
Is the GA-F2A88XN-WIFI Fm2+ motherboard compatible with the Cooler Master Seidon 120v cooler? The reason I ask is that in PCPartPicker coolers like the CM 120m and the h60 are listed in support for the Fm2+ socket but on the actual product webpage, no coolers seem to list the Fm2+ socket for compatibility. Are the dimensions of the Fm2+ socket the same as an fm1 or an fm2? Will I be able to put a Seidon 120v on an Fm2+ motherboard?
My assumption is that because the fm2+ socket is backwards compatible with fm2 processors, it has to be able to fit the stock fm2 coolers that come with the fm2 processors, so the 120v should be able to fit because it supports fm2?
