- Feb 15, 2014
- 119
- 0
- 76
This might seem a bit funny, but I have an old FM Stereo Speaker set which mysteriously stopped receiving fm broadcasts.
So, there are 2 jacks at the back:
45 ohm antenna
Ground
I got a really long insulated wire (just a simple stranded wire). The problem is all the set picks up is just a loud buzzing sound. For a second it picked up a signal, but then it went back to buzzing. I can confirm I receive FM signals in the area as it works perfectly with my mp3 player.
So: How / Should I build an antenna? Will sticking the antenna wire out of the window do?
Whats the ground connection for? I read its for the shield of a coaxial cable.. somewhere else it was a terminal for another wire which is supposed to be in another direction ??
Help please
45 ohm antenna
Ground
Help please
