alphatarget1
Okay resident CEs and MEs... Here is a question for y'all.
I have to find a pump that pumps water on a hill. 66' in height and the pipe is about 320' long. The calcs are shown below.
Hsys=Hpipe+Hheight+Hminor losses
We were looking at this pump with a flowrate of 120gpm. 2" diameter PVC pipe (assumed smooth) and avg. velocity is 12.25 ft/s
Reynolds # is 167416.4 and friction factor is .017 (sized up a little with the moody chart)
headloss from pipe will be (0.017)*(320')*((12.25ft/s)^2)/((2"/12")*2*32.174) =76.17 ft
headloss from tee is 3.5ft (assumed threaded tee with the K=2)
headloss from elbow is 4.7ft (assumed threaded with K = 1.5)
adding everything together the system head is 150'. That means a pump that provides 201' maximum head will work right? The shop people called the pump and told them what they needed to pump and the lady said we need a pump that has 350' and costs 2x as much. This is the first time I'm doing these types of calculations so any advice is appreciated!
