Fluid inside a heatpipe
996GT2
I need to bend the soldering at the end of one of the heatpipes on my AC Freezer 64 Pro to make it clear the side fan in my narrow Wave Master case. It does not need to be bent much, just a bit. i'm worried that I'll crack the solder and release the liquid (or whatever else) inside into the open air. Is the stuff inside a heatpipe dangerous in any way?
EDIT:
here's a picture of what I need to bend
http://i78.photobucket.com/albums/j120/996gt2/F64.jpg
think its better to bend your case side, or cut away at the side fan to fit.. or remove it😛 mercury..ouch
bend it carefully. Is the soldered point where it attaches to the fins or where it is sealed off? The heatpipes I've seen are crimped to seal them, the soldering is just to attach the pipes to the fins of the heatsink or whatever. So most likely if you crack the solder joint it won't leak or anything, and if you have a soldering iron or something you could probably solder it back again.
Not sure, but the pipe is definitely sealed at the ends. Not that it really answers your question...
If the fluid escapes, that heat pipe is rendered useless.
Nice post Howard!
Rule of thumb: Do not ever bend anything that was sealed with solder. Odds are you break the seal even if its crimped and soldered (which it most likely is anyway) and potentially face slowly degrading performance of the HSF.
yeah, it's probably better to modify your case instead of the heatpipe. If you can get it to be aesthetic looking, props to you!
but if you decide to bend it anyway, make sure you keep it hot.
Ok so it's most likely water in the heatpipe then according to the info page. I emailed AC, still haven't gotten a reply yet. However if it's most likely water I'll attempt it and if I crack the solder I can always re-solder the end, though the crimp sealing should keep it closed.
Don't expect to get a reply from AC. I emailed them about the Silencer making popping noises from the motor when undervolted about two months ago and they haven't sent me back jackcrap.
# For usual temperatures to meet electronics cooling requirements: Distilled water with various additions, organic substances like acetone (think nailpolish remover), methanol, ethanol (think booze), toluene (think magic markers).
# For high temperatures: Metals like mercury, sodium, silver.
so, looks like water or organic chemicals.
So whats so bad about mercury. Ya know there in those lightbulbs (the white, and energy efficent kinds).
The mercury VAPOR is very bad, the liquid, isn't really that bad. (asides from having a high(er) vapor pressure and turning into a gas, even a room temperature, which is most likely why it's so dangerous (i think, been a while since chem.)
WOW, AC REPLIED!!
Anyway, should be safe:
arctic cooling
to me
More options 1:00 am (12 hours ago)
Dear Sir
The heatpipes only contain water! You can try to bend the pipes, although we do not recommend this as this may cause the pipes to leak and thus stop working properly
arctic team
