flowcharting do statement - C programming- need help
rob_b
Can someone give me some examples of a do statement in a flowchart. I'm having trouble figuring out how to represent a do statement in the flowchart. Any help would be greatly appreciated.
i hope this will give you some idea .... it's "drawn" left to right instead of top to bottom .....
something goes to the beginning of flowchart -----*------> increment variable "i" by 1 ------- is "i" greater than 10? -----------> something else goes to the end of flowchart
from the diamond box (which usually denotes question), you can ask yes/no question, which leads to the "*" at the beginning (to re-enter the do-while loop), if the answer is yes, or goes to whatever follows later if the answer is no....
i hope it's going to give some imagination for you ....
here's another try .... drawn top to bottom ... hope the spacing won't mess up too much ....
............V......................................................................|
increment variable "i" by one......................................NO
....is "i" greater than 10?.............................................|
...........YES
............V
do something else
hope that helps ...
-1022-
edit: here is a simple gif image for that ....
