T
Tim
I'm wondering what flow rates are considered "ideal" if there is such a thing, and how what I have now compares to this number I should be looking for. Using my logic (which doesn't always serve me right), If the flow rate is too slow, it isn't as effecient in whisking the heat away from the copper blocks... then again if it's too high, it's not staying in the radiator long enough for the heat to be whisked away from the water. Correct me please if this logic isn't correct.
Now, moving along, I've input the following into the excel worksheet that's up @ martinsliquidlab.com.
The sheet assumes pure water (which is what I'm using), and 1/2" barbs for all curves (which I'm also using)
EK supreme waterblock
EK NB-S Max waterblock
Swiftech MCR-320 Radiator
Laing DDC-3.2 w/ XSPC Reservoir top
(Guesstimate here, I didn't measure!) 5' of 7/16ID tubing.
1 DD Derlin 90 elbow
1 DD Derlin TEE.
It comes up with an estimate based on my parts of 1.33GPM
If I take out the DD Derlin 90 elbow, it estimates 1.34GPM
If I take out the DD TEE on top of that it estimates 1.35GPM
If I replace the Swiftech MCR-320 rad with a thermochill pa120.3, it esimates 1.36GPM, and without the DD fittings, 1.38GPM
Lets just assume here for arguments sake that these estimates were the real deal as far as these flow rate numbers go. How close am I too a supposed 'ideal' flow rate (like I said in the beginning, if there is such a thing). Also, of the changes I listed, are their real benefits in making any of those changes seeing as the estimated flow rate only slightly increases, or is that slight increase more important that I'm realizing.
Lastly, on an off topic aside... where in the hell is derwinartos at? I haven't seen him in a bit.
1 DD Derlin TEE.
