Flossing before or after brushing?
j00fek
8,099
Before brushing, because youll have crap all over your teeth whenile your flossing
IceBergSLiM
29,932
my dentist flosses before he cleans. he went to many years of school for this stuff. i trust his method.
theknight571
2,896
Interesting....
My original dentist, and my current dentist (only 2 I've ever been to) both floss after brushing.
So I floss after brushing... figuring that's what they do... must be right. :)
theslickvik
558
Originally posted by: kt
Originally posted by: theslickvik
Before but here's the rub, you should rinse with an antisceptic (Listerene/Scope) as it will drain all the residual plaque that is there after flossing. Many times floss loosens the plaque but doesnt take all of it out. Using Listerene in tandem with the floss helps eliminate the problem :)
UCSF Class of 2003 Dental
What if I use flouride rinse? I use Listerene/Scope in the morning and flouride rinse at night.
Very nice regiment. Flouride rinses such as ACT should be used after brushing at night time as it strengthens your enamel allowing you to be less prone to cavities. You should also note that no food should be consumed after using a flouride based rinse because it would defeate the purpose of the product.
JS80
26,271
7
1) Floss to loosen food out of teeth
2) Rinse with listerine, kills germs and washes away loosened food
3) Brush, cleans your teeth and gets the stuff mouthwash didn't
OR
1) Brush, cleans your teeth
2) Floss, loosens food stuck in teeth
3) Listerine, rinses out flossed food and kills germs
Obviously the first works better. Here's what doesn't work:
3) Pay more money to dentist.
