Floppy won't format, help?
robisc
2,664
I am having problems with a combo floppy and flash reader drive, it is a Mitsumi FA404, I have tried this on 2 different systems and the cable is on properly, also it is enabled in the BIOS, problem is when I am trying to access the drive with a floppy in there, it does click like it is opening the cover and teh LED lights up, I then get the message floppy must be formatted, do you want to format now? I click yes and when it tries to format after a few seconds I get the error floppy can't be formatted, I have tried multiple disks as well. So I can't access the files or format the disks, does this sound like a hardware probelm or something else? Before I RMA it back to the Egg.
thorin
Did you try a different cable? (OR a standard known good floppy drive on the cable you're using) Does it read flash ok?
Thorin
robisc
2,664
I did try different cables, also the flash portion does works OK, it obviously is a just a multi-card reader that is bundled into a floppy drive, it has 2 different USB cables.
robisc
2,664
For the floppy cable, I have tried both a single rounded cable and a double twisted cable, both with the same results. For the PSU is it a Thermaltake Silent PurePower, 420W.
slirp
110
Sacrifice a 3.5 disk to the floppy gods. They are often appeased by this type of offering.
Infohawk
17,844
You tried it on other systems and it does't work right? Doesn't that pretty much mean it's internall broken?
robisc
2,664
I tried the original drive on 2 systems, but this is a new drive so i tried it on this system first (figuring it to work) and it does exactly the same thing as the other one.
