Floppy Error -> Drive A is Using MS-DOS Compatibility Mode File System
skho
82
Hi I have a problem with my floppy drive.
I have a Win ME system.
The floppy drive worked fine previously.
I installed a CDR burner.
I also installed an ethernet card.
Now everytime I try to access the a: drive it says to please insert disk. However the floppy disk will be there. Even worse the drive light does not even light up. So I checked the System icon in My Computer.
Here is what it says:
Drive X is Using MS-DOS Compatibility Mode File System
I tried to search for an updated driver but I already have the most updated one.
I also tried to remove/reinstall the floppy drive controller. But no luck.
Can someone help me fix this problem please?
Much thanks for any solution.
skho
82
P.S.
There is no conflicts or errors when I checked the Device Manager. The Performance Tab is where I saw the Drive X is Using MS-DOS Compatibility Mode File System. And I can't even access the a: drive now. Even when I switch to DOS I can't access it.
Is the radical solution to just partition/defrag hard drive and reinstall Windows?
