Any time i try to write to a floppy, it will tell me that it is write protected, no matter which disk i use. Is this a sure sign of drive failure? I will read but not write.
As was stated above, but also check in your bios for a setting called "Floppy R/W Control" or something similar. It may be set to Read, instead of Read/Write.
I know it sounds weird, but it's possible for it to be in this condition without frying something, and it causes exactly the symptom you are describing.
