hey. i have the same problem with my Toshiba 1800. However it works for a while (30 minutes), then craps out.
I figured it might be my inverter, but i havnt bought a replacement yet. I too have hooked up a vga monitor, and it comes up fine. I believe it something to do with the voltages going to the backlight. perhaps too much voltage coming from the motherboard to the inverter? Forgot to add. that i can cycle my outputs (lcd,vga,tv) and it comes back on... Sometimes for a while, but eventually it only flickers on for a second. Also, if i unplug the power. if it was in when the problem starts. the problem usually stops for a while, but then eventually it happends again.
All this leads me to believe the inverter is either getting too much, or too little voltage. Perhaps a resistor would help if voltage is too hight, or a capacitor if its too low?? I'm no electrical engineer, so i can only guess.. I am gonna pop open my laptop and monitor the voltage coming from the inverter, and see if it fluctuates. hopefully i dont mess stuff up more 🙂
Thanks,
KK
